Hisense KFR-25GW-06BP inverter air conditioner room air deflector motor drive circuit
Source: InternetPublisher:风向西瓜 Keywords: Hisense motor drive circuit inverter air conditioner Updated: 2021/03/28
Shown is the Hisense KFR-25GW/06BP inverter air conditioner room air guide motor drive circuit . The motor that drives the air guide plate to swing
is also called a blade motor. This motor uses a stepper motor, which uses a pulse signal drive method. , a certain
period of driving pulses will cause the motor to rotate by an angle. As can be seen from the figure, DC +12 V is connected to the center tap of the two sets of coils. The microprocessor
controls the four pins of the coil through the inverting amplifier. When a certain pin is low level, the winding connected to the pin There will be current flowing. If
the current of the winding is controlled according to certain rules, the desired rotation angle and direction can be achieved.
- How to remotely control devices using ESP8266 and LPC2148
- A simple door handle touch alarm circuit
- Manual automatic air compressor control circuit
- Squirrel cage asynchronous motor reverse braking control circuit
- Working principle of ZNB-S digital display intelligent motor protector control circuit
- Motor self-starting circuit
- Methods for Eliminating Noise of Brushed DC Motors
- Simple phase failure protection circuit composed of intermediate relay
- Design and analysis of the principle of automatic power-off switch during power outage
- PIC microcontroller controlled remote anti-theft alarm circuit
- Egg heating control circuit
- Multi-channel patrol detection control circuit c
- Multi-channel patrol detection control circuit a
- Remote control receiving circuit of Panasonic inverter air conditioner indoor unit control circuit
- Micro remote control receiving and control circuit
- Ringtone control circuit
- Assembly line outage monitoring circuit
- Internal functional block diagram and external circuit of Hisense KFR-25GW-06BP inverter air conditioner indoor unit microprocessor
- Bedside touch light detection control circuit
- Water dispenser (Aucma) temperature detection control circuit
