Bedside touch light detection control circuit
Source: InternetPublisher:失踪的猫 Keywords: control circuit touch BSP piezoelectric Updated: 2020/07/31
Shown is a bedside touch lamp detection and control circuit , which mainly uses a piezoelectric vibration sensor as the core sensing device.
In this circuit, when the human hand touches the small box equipped with the circuit, the piezoelectric vibration sensor BUZI converts the rotation signal into an electrical signal.
After being amplified by the transistor VT1, it outputs a low-level signal, which is driven by ICl-2 and IC1-3. The buzzer sounds; at the same time. VT2 is turned on, capacitor c3 is
discharged, IC14 works, and its @ pin outputs a high level,\ 13. VT4 is turned on, making the bulb HL light up.
- Signal diode arrays/configurations, freewheeling diode operation
- What is the difference between single-phase and three-phase power? When is three-phase power required?
- How to identify common mode interference? Methods to eliminate common mode interference
- What are the parts of the fpga design process
- How does RCCB work?
- How to build a triangle wave generator using an op amp and discrete components
- LED Night Light
- LED Bicycle Lights
- Experiment and production of NE555 time base integrated circuit
- FL52C4 induction electronic greeter
- Set timing circuit when power is on
- Self-defense anti-riot circuit
- Ultrasonic blind pathfinder circuit
- Homemade disinfectant circuit
- Electronic anti-asthma circuit
- Poultry warming temperature control circuit
- Broadband high frequency power amplifier circuit
- Second-order active band-stop filter circuit
- Sawtooth wave generator circuit (2)
- Sine wave signal generator circuit
