Touch switch circuit
Source: InternetPublisher:Lemontree Keywords: Switch circuit touch switch NAND gate BSP Updated: 2021/01/03
Shown is a touch switch circuit . When the metal plate M is touched by hand, the charge on CI will be added to the input terminal of
NAND gate 2 through the human body resistance, causing it to become a high level. Eventually, NAND gates 3 and 4 will output a high level, causing VT1, VT2 is turned on, relay Kl
absorbs the stage, and its contact Kl-l is closed, which can control the load operation. Since NAND gate 1 and NAND gate 2 are connected through resistor Rz,
the high level provided by cl to the input of NAND gate 2 will remain. Even if the hand leaves M, the circuit will remain in this state until until M is
touched again.
When the relay maintains the suction stage state, the input terminal of NAND gate 1 is low level, c] will be discharged to about ov through Ri and NAND gate l.
When M is touched again. C. The ov voltage is added to the input end of NAND gate 2 through the human body resistance . The circuit returns to its original
state, that is, rri and VT2 are cut off and relay Kl is released. K1.1 contact is open.
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- What are the challenges in designing a permanent magnet linear generator?
- How to set up a cheap beam break sensor control distance scene using a reflector
- JDB-LQ-TQ/2 motor full voltage starting circuit
- Starting method of asynchronous motor with external frequency-sensitive resistor
- Design and principle analysis of practical electric curtain remote control device
- Design and production of radio remote control fan stepless speed regulator
- Hydraulic control circuit design and analysis
- PIC microcontroller controlled remote anti-theft alarm circuit
- Infrared detection alarm
- electromagnetic field sensor
- strain sensor
- stuttering correction circuit
- Homemade disinfectant circuit
- Fish pond oxygenation reminder circuit
- Frequency modulator composed of NE566
- Diode balanced amplitude modulation circuit
- Double gate field effect transistor high frequency amplifier circuit
- common emitter amplifier circuit
- Home appliance repair signal generator circuit
