Surround sound AD converter circuit c
Source: InternetPublisher:张七岁 Keywords: D converter A/D converter audio signal Updated: 2021/09/10
Shown is the A/D converter circuit. The processed 6-channel audio signals (5.1 audio) are divided into 3 groups and passed through 3
A/D conversion integrated circuits respectively to convert the analog audio signals into digital audio signals. This Digital audio signals are called serial digital signals. Each
group is composed of three signals, transmitted simultaneously. Among them, Dout is the serial data signal, also called Date, BCK is the serial clock signal, and LRCK
is the left and right (LR) separated clock signal.
Among the three A/D converters, the main channel (L, R) uses a 24-bit A/D converter, mainly to ensure the frequency bandwidth of the main channel,
low distortion, and large dynamic range. Surround sound (SL, SR) A/D converters and mid-channel and subwoofer A/ D converters all use 16-bit quantization
values.
- Ultrasonic atomization principle diagram
- Feiyue WP-600 computerized microwave oven computer control diagram
- Triangle, Yuanling, Gold CFXB type double lamp rice cooker circuit diagram
- Lihe ESA-25 temperature-adjustable electronic crock circuit diagram
- Senlan BT40 multi-unit proportional linkage
- Northern brand BD-90 refrigerator circuit
- Tube amplifier TDA1541 parallel circuit diagram
- Kana brand BD-130 refrigerator circuit
- Amplifier DIR1703+PCM1738 DAC PCB circuit diagram
- Touch fan speed regulator circuit
- audio signal encoder circuit
- Circuit structure of audio AD converter
- AD converter AD9887 circuit
- Reference voltage divider circuit in AD converter
- 3-bit AD converter circuit structure
- AD converter and display circuit (ICL7126)
- Two-channel audio signal conditioning circuit
- Timing circuit with audio control
- audio signal amplifier circuit
- Low power audio signal amplifier circuit
