Hitachi RAS-5102 inverter air conditioner remote control transmitter circuit diagram
Source: InternetPublisher:傻阿乐 Keywords: Hitachi circuit diagram remote control transmitter circuit Updated: 2020/01/12
Shown below is the remote control transmitter circuit diagram of Hitachi RAS-5102 inverter air conditioner . The ICl (SMC6214FOY) in the circle
is the modulation and encoding integrated circuit for the remote control signal. It is actually also a signal processing chip. The integrated circuit is powered by 3V DC voltage.
This circuit is connected to two external crystals Xl and X2. Xl has a lower frequency and is a secondary oscillator. It mainly provides character
clock signals for timing and character display circuits. X2 is the main oscillator, which provides the clock for the modulation and encoding circuit, and forms the carrier signal of the remote control data after frequency division.
The leads of @~@ pins and @~@ pins form a key matrix operation keyboard circuit, and operation keys are set at the intersection points of each lead to
provide key input signals for IC1. ICI codes according to the key input signal and the data stored in the internal memory, and then modulates the coded signal.
The modulated signal is output from the @ pin. After being amplified by the driving transistor Q1, the modulated coded signal is added to the infrared light-emitting diode Dl
. At the negative terminal, the power supply 3V is added to the positive terminal of Dl, and Dl emits an infrared light signal.
- Methods to reduce mutual coupling between antenna elements
- Change the frequency of the campus radio
- FM microphone made by 9018
- Convenient and practical telephone automatic redial controller
- MGCT02 I/Q TDMA/AMPS l900/900 MHz Dual-Band Dual-Mode Transmitter
- QMR1/QMR2 AM/FM 868/433.92 MHz Receiver Module
- RF2909 GMSK/QPSK/DQPSK/QAM 915 MHz Transmitter
- RF2926 AM/FMASK/FSK/OOK 915/ 868/433 MHz Dual Conversion Transceiver
- TQ5638 KPCS CDMA/GPS 2090 ~ 1620 MHz Dual Mode Receiver
- MICRF500 FSK 1000~700 MHz Transceiver
- Integrated oscillating infrared transmitter circuit
- Toy wireless remote control transmitter circuit
- MK5087+TWH630 remote control transmitter circuit diagram
- Equal sub-wave transmitter circuit with power 1W
- TC1948P (video recorder) infrared remote control transmitter circuit
- BL50462 (TV) infrared remote control transmitter circuit
- Infrared emission circuit composed of "NAND" gate
- Modulated infrared transmitter circuit
- Remote control helicopter transmitter circuit diagram
- LR3714M infrared remote control transmitter circuit
