How to solve the problem that the battery of MacBook Pro is not charging after plugging it in?
Source: InternetPublisher:张七岁 Keywords: mac charging mac power supply smc Updated: 2020/06/02
How to solve the problem that the battery of MacBook Pro usually does not charge when it is plugged in?
Model: MacBook Pro 2018
Phenomenon: After confirming that the power supply is normal, the battery does not charge after connecting to the power supply. This phenomenon is irregular and occurs occasionally.
Reason: Mac has an SMC module. Whether to charge the battery is controlled through the SMC. Sometimes the control logic may be abnormal. Just reset the SMC.
Method: https://support.apple.com/zh-cn/HT201295#t2
Choose Apple menu > Shut Down.
After your Mac shuts down, hold down the right Shift key, left Option key, and left Control key for 7 seconds. Then, while holding down the power button, continue to hold the keys for 7 seconds.
Release all three keys and the power button and wait a few seconds.
Press the power button again to turn on your Mac.
- Benefits of Wide Bandgap Technology for Power Converters
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Practical and convenient fax machine power supply control circuit
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- LED rechargeable flashlight circuit diagram
- Current/voltage conversion circuit using current converter
- Dual forward converter schematic diagram
- CNC regulated power supply production
- LM317 regulated power supply
- Homemade home inverter circuit diagram
- Portable device charging power circuit design
- Power circuit of LBO-522 dual trace oscilloscope
- Output 12V-10A power supply circuit
- Warm current power supply circuit b
- CF1 (CF2) DC power supply circuit
- Power circuit for home appliance repair
- Common power circuits and applications 06
- Inverter power circuit made with BJ50A
- 5V, 7.5V, 48V power circuit
- ±5V, ±12V power circuit A
