kitchen timer circuit
Source: InternetPublisher:ohahaha Keywords: timer circuit kitchen timer Updated: 2021/10/15
Shown is a typical timing prompt circuit. The main body of the circuit is an ICl CD4518 counter circuit with a built-in oscillation circuit.
After the power is turned on, IC1 is reset and the counter starts to work. After a certain counting cycle of the power switch (64 cycles), Q7-Q10 terminals
successively output high level . When Q7-Qro are both at high level , the timing time is up, VTI is turned on, and the buzzer sounds to indicate the time.
- How to use a microcontroller to control a servo motor?
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- Tutorial on making your own remote-controlled robotic arm
- Design of an autonomous plant watering system using ATtiny85
- How to remotely control devices using ESP8266 and LPC2148
- Controlling LEDs with Node-RED in Raspberry Pi
- Replace the GE LOGIQ a200 ultrasound measurement key with a self-made touch switch
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Simple three-phase motor phase loss protection circuit
- Homemade anti-theft watchdog
- Install a timer circuit on an electric vehicle
- Add a timer circuit to the radio
- Cycle time voltage controlled timer circuit
- Pocket electronic timer circuit diagram
- Programmable timer circuit diagram
- Amplifier timer circuit diagram
- Circuit diagram of a timer that is set as soon as the power is turned on
- Timer circuit diagram that resets when power is turned on
- 7x9 level adjustable timer circuit diagram
- Simple and accurate timer circuit
