Turn signal prompt circuit
Source: InternetPublisher:吃掉星星 Keywords: turn signal oscillation Updated: 2021/03/12
Shown is a turn signal prompt circuit. When the car turns, the turn signal relay sends voltage to the turn signal prompt circuit, and
the NE555 time base circuit is powered to generate an oscillation signal . The ③ pin output goes through VT to drive the buzzer to sound. Alert the driver.
- A white light LED power outage emergency light
- DIY a hat with a programmable LED display
- Measurement and analysis of automatic emergency lighting circuit
- Solar battery and charging circuit
- One of the water full alarm circuits
- AC and DC dual-purpose flash light
- Large light emitting diode display circuit
- Shock resistant soft start constant current LED lighting circuit
- Four color light circuit
- Reverse polarity drive circuit
- Infrared remote control transmitter circuit
- The oscillation process of a multivibrator a
- Woodworking machine tool circuit b
- Switching power supply circuit diagram using TDA4605-2
- Oscillation experimental circuit
- Voltage Controlled ECL (Emitter Coupled Logic) Integrated Circuit Crystal Oscillator Generator Circuit
- Square wave oscillation generator circuit using LM359
- Oscillation detection automatic watering controller circuit
- Ring oscillator pulse generator circuit diagram
- High stability Wien bridge oscillator circuit diagram
