The oscillation process of a multivibrator a
Source: InternetPublisher:通通 Keywords: multivibrator VR oscillation Updated: 2021/07/12
It can be seen from the circle that when vri is turned off, \0[2 is turned on, and the current passes through RJ and Ci: When VT1 is turned on,
the charged Cl begins to discharge. Then charge cl in reverse phase, the №I voltage becomes positive, and vri becomes conductive. So uc: approaches 0, causing the base of VT2
to become negative, and VT2 becomes cut off again. In this way, VT1 and VT2 are turned on and off alternately to form an oscillation state.
- Does lithium iron phosphate battery need a protection board? The correct way to charge lithium iron phosphate battery
- The unidirectional conduction current of the diode, the diode and its common uses
- How are diodes made using semiconductors?
- What is a Half Wave Rectifier? Working Principle of a Half Wave Rectifier
- Types and structures/characteristics/functions/implementations of smart sensors
- Causes and solutions for noise in digital Class D amplifiers
- RC filter explained in detail
- Basic characteristics/working principles and application circuits of tunnel diodes
- How to Build a Simple Temperature Indicator Circuit Using NTC and PTC Thermistors
- How to build a triangle wave generator using an op amp and discrete components
- Triode color changing flash circuit diagram
- Working analysis of push-pull output
- Household vegetable storage room temperature stabilizer circuit
- Multivibrator Practical Circuit 02
- Multivibrator Practical Circuit 01
- How multivibrator works
- Multivibrator circuit with adjustable duty cycle and constant frequency
- Multivibrator circuit with two outputs
- Monostable multivibrator circuit with input blocking
- Multivibrator using thyristors
