Temp-Flex TwinMax high temperature resistant, low loss twinaxial cable, did you know?
Source: InternetPublisher:红水杯 Keywords: twinmax twinaxial cable Updated: 2021/02/17
What is Temp-Flex TwinMax High Temperature Resistant, Low Loss Twinaxial Cable? Did you know? Molex introduces Temp-Flex TwinMax High Temperature Resistant, Low Loss Twinaxial Cable, a multi-impedance, range balanced transmission cable suitable for connections 10, 12 and 28 Gbps circuits in data centers and telecommunications equipment.
Temp-Flex TwinMax high-temperature resistant low-loss twinaxial cable monitors diameter, concentricity and capacitance online, and uses a real-time closed-loop control system to monitor the extrusion, taping and wiring processes. Statistical monitoring of processes provides proprietary processes and precision manufacturing capabilities. Its small bend radius and high bandwidth improve signal integrity and provide excellent overall performance. Cables capable of carrying signals at 10, 12 and 28 Gbps are available to meet a range of signaling needs. It offers twin-axial cables in 85, 90 and 100 ohm versions for a variety of applications. And with complete components of I/O devices and enterprise connectors, it provides an end-to-end high-speed solution. Thermal and mechanically stable, high temperature resistant, dielectric (-20 to +105 degrees Celsius), withstands soldering temperatures and is easy to terminate. Insertion loss remains stable at high temperatures, highest reliability, flame retardant rating: VW-1 meets standardized fire safety standards and is UL recognized to meet UL style standards.
Temp-Flex TwinMax high temperature resistant low loss twinaxial cable can be used in telecommunications/networking, such as servers and backplanes. This technology will also be used in internal servers and backplanes of data center solutions. In the automotive industry, it is also suitable for infotainment systems and autonomous vehicles.
As an authorized distributor of Molex, Heilind can provide relevant services and support to the market. In addition, Heilind also supplies products from many of the world's top manufacturers, covering 25 different component categories, and values all market segments and all customers. Constantly seeking a broad product offering to cover all markets. The above is the analysis of Temp-Flex TwinMax high temperature resistant, low loss twinaxial cable. I hope it can be helpful to everyone.
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- Single-power supply circuit for ISO122P/ISO124
- Constant current LED lamp driver circuit with soft start and anti-shock
- LED rechargeable flashlight circuit diagram
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Boost drive circuit composed of RT8450
- A small and easy-to-make fast charger
- Converting a lithium battery charging board into a constant voltage and current charger
- Mc34063 MP3 Switching Charger
- Car Audio Power Supply
- Power circuit of STR5412
- Power supply circuit with multiple outputs (MAX1902)
- 4-phase CPU power circuit using HIP6301 and HIP6602 chips
- Warm current power supply circuit b
- audio power circuit
- Additional power circuit design for USB devices
- Antenna amplifier synchronous power supply circuit
- Practical neon light power circuit
- AC-DC conversion power supply-inverter power supply circuit
- CASPER TM-5158 VGA color display power supply circuit
