Silent timer reminder circuit
Source: InternetPublisher:jikai233 Keywords: reminder counter Updated: 2020/07/04
![Silent timer reminder circuit](http://www.eeworld.com.cn/circuit/upload/6120b57dc6909b5cfee28b2247b42ab7/9aa163acaa6c39a9864d83a759c5eee4.gif)
Working principle of the circuit : After the power switch is turned on, the circuit automatically resets its operation so that each IC is in its initial state. The reference signal generating circuit 8651B generates a signal of 1/60 Hz, which is input to the reverse counting end of the counter 74HC192. 74HC192 is a presettable 4-bit forward and reverse counter. By changing the IC input terminal, it can be used as a forward or reverse counter .
- The basic principles of power supply design. What are the key components of a power supply?
- Basic characteristics of power field effect tubes, how to improve the dynamic performance of power MOSFET
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- Driving circuit that controls LED brightness using PWM signal
- Charging control circuit made by solar energy
- Dynamic power supply for power amplifier controlled by thyristor
- A small and easy-to-make fast charger
- Adjustable regulated power supply with current limiting protection
- MIC4680 constant current charger
- Detailed explanation of mobile phone charger circuit diagram
- Power circuit of STR5412
- Laser power circuit
- Dual adjustable power circuit
- Power circuit of LBO-522 dual trace oscilloscope
- Output 12V-10A power supply circuit
- 3-phase CPU power circuit using HIP6301 and HIP6601 chips
- Practical neon light power circuit
- Common power circuits and applications 01
- Telephone power circuit
- Lecture time limit reminder circuit
