Do you know about the new current sensor for industrial applications?
Source: InternetPublisher:三岁就很酷 Keywords: Photovoltaic inverter current sensor Infineon Updated: 2020/08/05
What is a new current sensor for industrial applications? What does it do? Munich, Germany, May 10, 2019 - Infineon Technologies AG (FSE code: IFX / OTCQX code: IFNNY) will release a new current sensor family series of products and debuted at this year’s PCIM trade show with its first family member. This family of products will consist of highly accurate and stable coreless Hall sensors. They offer high flexibility, allowing customers to individually set product parameters such as current range, overcurrent threshold and output mode.
The first product, the XENSIV™ TLI4971, has a measurement range of ±25 A to ±120 A. It is suitable for industrial applications such as electric drives or photovoltaic inverters up to 50 kW. Additional members of this product family will be available in 2020 and are suitable for automotive applications.
Image Caption: XENSIV™ TLI4971 current sensor for industrial applications enables highly accurate, stable current measurements
This coreless open-loop current sensor enables highly accurate, stable current measurements and provides an analog output voltage. Based on Infineon's temperature and stress compensation technology that has been proven in the market, its sensitivity error at room temperature is as low as 2%. With single-point in-system calibration, it can be reduced to less than 2%. Not only that, using two Hall sensitive elements for differential measurement can ensure high measurement accuracy even in noisy environments filled with crosstalk from adjacent current lines or magnetic stray fields.
The TLI4971 has two output pins to support fast overcurrent signals. Customers can set the overcurrent signal threshold to meet system requirements without the need for additional external components. These signals can be used to issue early warnings and shut down the system. In addition, the device can also provide overvoltage or undervoltage status signals on the supply voltage.
Thanks to the coreless concept, the TLI4971 can be placed in an 8x8x1 mm leadless QFN type package (TISON-8). The current rail layout enables excellent thermal performance and supports up to 120 A without incurring additional cost. The device is suitable for high-voltage applications and provides electrical isolation performance up to 1.1 kV (maximum repetitive isolation voltage V IORM). The above is the analysis of the new current sensor for industrial applications. I hope it can help you.
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Use pulse width modulation to get a precise output voltage
- Simple and practical LED lamp driving circuit
- Dynamic power supply for power amplifier controlled by thyristor
- Adjustable regulated power supply with current limiting protection
- Integrated regulated power supply with continuously adjustable output voltage
- 0.7~24V continuously adjustable current limiting power supply
- Mc34063 MP3 Switching Charger
- MAX1811 Lithium Battery Charger Production
- Homemade Electric Bike Fast Charger
- Analysis of key points for sensor selection
- Power circuit of STR5412
- 2-phase CPU power circuit using HIP6302 and HIP6601 chips
- 2-phase CPU power circuit using HIP6301 and HIP6601 chips
- KGDS type single-phase low temperature iron plated power supply circuit
- Remote control TV doorbell power circuit
- Common power circuits and applications 08
- Common power circuits and applications 04
- Always ready power circuit
- High quality power supply circuit schematic diagram
