New high-performance varistors, do you know?
Source: InternetPublisher:fish001 Keywords: Vishay high performance varistor vdrus series Updated: 2021/07/17
Did you know that Vishay has launched a new high-performance varistor specifically for consumer electronics and industrial electronics? June 26, 2019 - Recently, Vishay Intertechnology, Inc. (NYSE stock code: VSH) announced the launch of a new series of VDR metal oxide Material Varistor (MOV)---VDRUS series, certified operating temperature up to +125 C, compliant with UL 1449 4th edition and VDE/IEC 61051-1/2 standards. Vishay BCcomponents VDRUS series resistors are specially designed for overvoltage and transient voltage protection in consumer electronics and industrial applications. Their surge current resistance is 30% higher than the previous generation devices.
The devices launched recently consist of high-purity zinc oxide chip resistors, available in standard dimensions of 7 mm, 10 mm, 14 mm and 20 mm, with two solid copper leads or matte tin copper-clad steel wires. The new varistor has excellent high-temperature performance thanks to its UL94-V0 rated flame-retardant silicone coating, which provides electrical, mechanical and weather protection.
The VDRUS series electrical resistors have surge currents from 1.8 kA to 13 kA, rated voltages from 115 VAC to 680 VAC, and energy absorption from 19 J to 720 J. They are available in straight or curved lead forms. Varistors are suitable for use in power supply controllers and input filters in household appliances such as electric stoves and washing machines, as well as in industrial applications such as motor controllers, AC/DC converters and circuit breakers.
The device complies with RoHS standards, is halogen-free, and is suitable for automatic plug-in assembly, wave soldering and pin-immersed solder paste reflow soldering processes. The above is the analysis of Vishay’s new high-performance varistor specially designed for consumer electronics and industrial electronics. I hope it can be helpful to everyone.
- How about the boost converter TPS61299?
- 5 Converter Topologies for Integrated Solar and Storage Systems
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- Using Lead-acid Battery as Power Source for Walkman
- LED Driver ZD1680
- Switching power supply circuit composition and function introduction of each part
- Parallel DC regulated power supply circuit diagram
- An ultra-low output voltage regulator
- Constant current charger using light emitting diode as voltage regulator
- Design of electric vehicle charger
- Excellent performance household inverter power supply circuit
- DC 12V to AC 100V inverter power supply circuit design
- Commonly used power circuits in printers
- Warm current power circuit a
- Super Class A power amplifier power circuit
- Remote control TV doorbell power circuit
- Neon light high voltage power supply circuit
- Common power circuits and applications 09
- Common power circuits and applications 07
- Inverter power circuit
