Car anti-theft alarm circuit (1)
Source: InternetPublisher:同住地球村 Keywords: Car anti-theft alarm anti-theft alarm circuit BSP Updated: 2020/05/31
With the improvement of people's living standards, there are more and more private cars, and the problem of anti-theft has become more prominent. This inverter circuit is simple and reliable. It only costs a few yuan
to make the anti-theft alarm sound and cut off the lights when the car door is pried open. and oil circuit, preventing the car from starting.
(1) Analysis of circuit working principle The circuit composition is shown in Figure 13-33.
555 time base integrated circuit as a delay oscillator. The function of the delay is to delay the alarm for 30 to 60 seconds after it is triggered, so that the owner
has time to turn off the alarm
when the owner opens the door .
When the owner leaves the car and the car door is pried open by the car thief, the contact switch
SB is closed, the relay Kl is energized and operates, the normally open contacts Kl-l and Kl-2
are closed , and the Kl-l contact is closed. The relay is self-locking, and the Kl-2 contact is closed so that the main circuit
is powered on and starts working. When the voltage at point A rises to greater than or equal to 213Uce,
the ③ pin of the output terminal of the 555 time base detection circuit outputs low level, the relay K2 acts, and
the normally open contacts K2-1 and K2-2 close, causing the car speaker to beep continuously. An alarm
sounds; at the same time, using the contacts of relay K2, the car lights and oil system can also be turned off and the car cannot be started .
- Working Principle of CCFL and Analysis of Electronic Driving Circuit
- LED Flasher circuit using 2 transistors for LED switching
- Design and production of a practical electronic counting device
- Use MC1455PIG to make automatic cycle light-emitting diode circuit
- battery charging circuit
- Infrared remote control dimmer light circuit
- Electronic music dimming desk lamp circuit
- Microwave Doppler warning circuit
- Economical and practical delay light circuit
- Automotive LED driver circuit diagram using LT3486
- electromagnetic field sensor
- stuttering correction circuit
- Egg warming circuit
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Mixer built with analog multipliers
- Junction field effect transistor mixer circuit
- Diode square rate detection circuit
- Broadband high frequency power amplifier circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Voltage-controlled voltage source second-order band-pass filter circuit
