AD596-597 functional diagram
Source: InternetPublisher:toothache Keywords: AD thermocouple BSP power supply Updated: 2020/05/05
High temperature measurements often require thermocouples as temperature sensing elements. Due to the nonlinearity of the thermocouple output,
linear compensation is required when amplifying the thermocouple output. AD594-597 is a special amplification, linear compensation and control
circuit for thermocouples.
AD594/595 are thermocouple signal amplification and cold junction compensation monolithic integrated circuits. Their functional principles and pin definitions
are the same. The difference is that AD594 is equipped with a J-type thermocouple and AD595 is equipped with a K-type thermocouple. The output is low impedance, the voltage
output is 10mV/oC, and the resolution is 1℃. The working power supply range is t5v~±15V.
AD596/597 is a thermocouple signal amplification and temperature control
circuit. They have two models with different suffixes, namely
AD596AH/597 AH and AD596AR/597AR.
The functional principles and pin definitions of the two models are different,
but the functional principles and
pin are the same. Mainly The difference is that the AD596 is equipped with a J-
type thermocouple, and the AD597 is equipped with a K-type thermocouple . The output
is - 10 rv/cC; the working power supply range is +5~
+30V. AD594/595 functional diagram is
shown in the figure. AD 596/597 functional diagram is shown in the figure
- What is the function of a voltage regulator in a circuit? How to connect a voltage regulator?
- Why do we need a MOSFET gate resistor? MOSFET Gate Resistor Placement
- Signal diode arrays/configurations, freewheeling diode operation
- What factors are related to the hysteresis loss of the transformer? Can the hysteresis loss be reduced?
- The Importance and Ideal Model of Impedance Matching
- How do you calculate the value of capacitors in series? Why use capacitors in series?
- How to build a drag racing timer circuit using a 7-segment display and discrete components
- Tutorial on building a NOT gate using BJT transistors
- How to install the accelerometer
- LED Bicycle Lights
- AD power supply circuit design experience, worth collecting
- AD8202 two-stage system structure application circuit diagram
- AD7730 internal functional block diagram and pin function diagram
- AD594-595 functional diagram
- Introduction to the high-precision ±5V reference source AD586
- AD2S80A typical connection circuit
- Permanent magnet servo motor field oriented control
- AD590 circuit diagram
- Electronic transformer circuit
- Changfeng KAB-11, KAD-12, KAD-18 wall ventilator circuit diagram
