Electric soldering iron power saving circuit
Source: InternetPublisher:JFET Keywords: save electricity power supply Updated: 2021/05/26
Common soldering irons are generally directly powered by 220V , but in actual work,
sometimes we don't want it to heat up for a long time, which will waste electricity on the one hand. On the other hand, it also
accelerates the aging of the soldering iron tip. Power on when in use and cut off when not in use, and the heating process is
too long. When the circuit below is welding, 2ZOV supplies power and the soldering iron works normally. When
the welding is paused, the diode half-wave rectification is used, and the soldering iron works at a lower voltage to
maintain a certain temperature . When welding is resumed, the soldering iron quickly rises to the normal
temperature without affecting the welding.
- A wireless doorbell circuit
- Integrated AM and FM radio circuits for household appliances
- Hemisphere brand BC-175 refrigerator circuit
- LA5521D DC motor speed stabilizing circuit
- Relay power saving circuit 2
- Lihe ESA-25 temperature-adjustable electronic crock circuit diagram
- Senlan BT40 multi-unit proportional linkage
- Transformer AC contactor DC operation circuit a
- TV automatic frequency control circuit
- Refrigerator shell live alarm circuit
- Machine tool no-load self-stop power-saving circuit
- Electric iron power saving circuit
- TN-S power supply mode circuit
- Power outage emergency light (1)
- Power supply for sounder circuit
- Mains powered photoelectric smoke alarm circuit diagram
- Electronic limited power supply circuit
- Audio powered noise limiter
- Voltage stabilizing circuit for non-AC power supply
- Power frequency induction furnace thyristor voltage regulation power supply control circuit
