TN-S power supply mode circuit
Source: InternetPublisher:两手空空 Keywords: Power supply BSP switch Updated: 2020/11/05
There are many power supply methods, but other power supply methods have certain shortcomings. Only the TN-S method is better. Therefore, this section only introduces the TN-S power supply
method.
The TN-S power supply mode is mainly used when the three loads are basically balanced, as shown in the figure. It strictly separates the working neutral line and the dedicated protection line PE
, or provides independent power supply. The characteristics of TN-S power supply are as follows:
1) The working neutral line is used as a lighting circuit .
'2) Under normal operating conditions, there is no current and voltage on the special protection line PE, and there is unbalanced current only on the neutral line. Therefore, it is safe for the electrical equipment shell
to be connected to the zero protection line and to the special protection line. 7
3) The special protection line is not allowed to be disconnected, and it is not allowed to enter the leakage switch .
4) When installing a leakage switch on the trunk line , there must be no repeated grounding on the working neutral line, while there can be repeated grounding on the PE line, but it does not pass through
the leakage protector.
5) The TN-S power supply method is suitable for industrial and building electricity use. It is safe and reliable and is our preferred way of using electricity.
- How about the boost converter TPS61299?
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- Benefits of Wide Bandgap Technology for Power Converters
- Fabrication of multi-cell lithium battery charging circuit
- Use pulse width modulation to get a precise output voltage
- Charging control circuit made by solar energy
- Adjustable regulated power supply with current limiting protection
- Adjustable voltage power socket
- Adjustable voltage regulated power supply circuit
- A low-cost, high-reliability battery charger for electric vehicles
- Inpatient pager circuit
- Rice mill circuit
- Particle clogging alarm circuit of wheat seeder
- Greenhouse temperature control circuit
- DC ammeter
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Domestic KD8041 integrated phase locked loop
- Integrated synchronous detector composed of analog multiplier MC1596
- common emitter amplifier circuit
- Motorcycle flash light circuit
