Constant voltage drive measurement circuit
Source: InternetPublisher:闪电杰克 Keywords: Measuring circuit BSP Updated: 2021/02/11
When 1832 is used for bridge measurement, the peripheral circuit is very simple, as shown in the figure.
Adjust the driving voltage (@ pin) of the sensor measurement bridge. Its adjustment range is +4 to +10V.
The specific value is determined according to the actual needs of the sensor. The two fixed gain 333.3 and 500 pins ⑩ and ⑩ are active when connected to low level, and the gain of 100~
5000 is continuously adjustable depending on the RF/R of ⑨ and @ pins. The output voltage is ±10V.
- What is a Half Wave Rectifier? Working Principle of a Half Wave Rectifier
- What is the difference between single-phase and three-phase power? When is three-phase power required?
- How do Zener diodes protect circuits?
- The Importance and Ideal Model of Impedance Matching
- What are the main types of resistors? Detailed explanation of the functions and uses of resistors
- Diode-based clipping circuit
- Basic characteristics/working principles and application circuits of tunnel diodes
- How to Build a Simple Temperature Indicator Circuit Using NTC and PTC Thermistors
- Using an Op Amp to Drive a Simple and Practical Power Amplifier
- Experimental circuit based on 4040 binary adder counter
- Analysis of rectifier circuit types and principles
- Self-defense anti-riot circuit
- Ultrasonic blind pathfinder circuit
- Pulse therapy circuit
- DC ammeter
- Double detuned loop frequency discriminator circuit
- Motorcycle flash light circuit
- Various signal generator circuits
- Home appliance repair signal generator circuit
- Sawtooth wave generator circuit (1)
