High impedance pH detection amplifier circuit
Source: InternetPublisher:smallembedded Keywords: Amplification circuit impedance OPA Updated: 2021/12/23
The pH value is a measure of the acidity or alkalinity of a solution. As shown in the circuit shown in the figure,
when the pH probe comes into contact with the solution being measured, its resistance value will change according to the strength of the acid and alkali. This change forms a current at pin ③, which is amplified by OPA 111
and outputs a voltage signal. The gain of the circuit is determined by R2/Ri.
- Why do we need a MOSFET gate resistor? MOSFET Gate Resistor Placement
- Analysis of the flow direction of transistor current
- How to read resistor color codes? Resistor color codes illustrated
- What is power factor and three ways to improve it
- Why use PWM? What are its advantages?
- Tutorial on building a NOT gate using BJT transistors
- LED lights that “drain” battery power
- LED Night Light
- FL52C4 induction electronic greeter
- A practical automatic electronic welcome circuit
- common emitter amplifier circuit
- Pin function diagram of OPA111
- Broadband amplifier circuit
- Voltage amplifier circuit
- High output voltage amplifier circuit
- Practical amplifier circuit c composed of operational amplifier LM386
- Practical amplifier circuit b composed of operational amplifier LM386
- Three amplification circuits of junction field effect transistors - common drain
- Headphone amplifier circuit using dual operational amplifiers such as OPA2604
- OPA404 type operational amplifier circuit
