Intelligent Motor Speed Counter
Source: InternetPublisher:elleny Keywords: Motor Counter Updated: 2024/10/14
CD4511 is a BCD-seven-segment LED latch/decoder/driver. When LE is low,
the data added to the A, B, C, and D terminals are translated into segment drive signals and sent to the segment control line of the digital tube through the current limiting resistor. When LE is high, the drive signal is latched at the output of CD4511 to achieve static display. Since the output of CD4511 is high level effective, a common cathode digital tube is selected. D1 is a working indicator light for debugging.
The debugging of this circuit is divided into two parts: software and hardware. It is recommended to check whether the sensor is working first, which can be seen from the display of D1. LED display requires the help of software. This article is accompanied by a debugging program ts. Asm. Execute the program step by step. If the digital tube does not display 789, then there must be a problem with the hardware. Please check carefully. When you are sure that the hardware is correct, you can enter the main. Asm program. After the simulation debugging is passed, write the program into AT89C51, and the circuit design is completed.
This system can correctly count the motor rotation within the range of 0 to 999 rpm, meeting the needs of production. With a slight modification of the circuit, it can also be expanded to a pulse frequency meter, etc.
- How to build a soldering iron heat controller circuit using microwave parts?
- Analysis of the working principle of the sound and light controlled delay switch circuit
- A simple magnetic switch circuit sharing
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- One-way rotation circuit of motor controlled by contactor
- Hydraulic control circuit design and analysis
- Do-it-yourself trial production of phase failure protection device
- Design and manufacture of three-phase motor protection circuit
- Motorcycle anti-theft device circuit design
- Agricultural spraying and insecticide control circuit
- Stapler control circuit
- Electromagnet control circuit
- DC voltage stabilizing circuit and zero-crossing detection circuit in the indoor unit control circuit of Hisense KFR-25GW-06BP inverter air conditioner
- PLC light source robot hand bubble control circuit
- Bedside touch light detection control circuit
- Micro DC motor steady speed control circuit b
- Temperature measurement and control circuit
- Typical electronic volume control circuit
- Apply LOGO! Electric gate control circuit b
