Digital display electric heating furnace automatic temperature controller
Source: InternetPublisher:MartinFowler Keywords: Temperature controller automatic temperature control electric heating furnace Updated: 2020/06/06
This circuit can automatically control the heating of electric heating equipment such as heating furnaces, and use digital display to set (control) the temperature
. It is intuitive, convenient and flexible to operate. The digital display electric heating furnace automatic temperature controller is shown in Figure 1-26.
The functional principles of AD596/597 are basically similar to AD594/595. Compared with the circuit in Figure 1-25, using
AD596/597, the temperature setting and temperature control circuits are more simplified. The signal is output from the ⑥ pin and divided into three channels: one channel is sent to the
A/D conversion IC 4 for processing, and the temperature value is displayed on the LED digital tube. The other channel is fed to the feedback input pin ⑤ to
form feedback amplification inside IC1. The third path sends a voltage comparator composed of IC2 to
compare the potential of terminal (one) with the potential of terminal (+). When the potential of terminal (one) is lower than the potential of terminal (+), that is, the temperature detected by TC has not reached the predetermined level. Assume
that the temperature
of When, the output of IC2 becomes low level
and heating stops; similarly, after heating stops, when the temperature drops below the predetermined temperature, heating starts automatically again. MA
is used to set the hysteresis voltage, IC 3 provides a +5. OV reference voltage, and RP is used to set the temperature control point and control the temperature
- What is a Half Wave Rectifier? Working Principle of a Half Wave Rectifier
- What are the main types of resistors? Detailed explanation of the functions and uses of resistors
- How to read resistor color codes? Resistor color codes illustrated
- FPGA Features and Architecture
- What are the types of commonly used batteries?
- Beautiful crown wreath made with LED
- What is the difference between high-side and low-side resistive current sensing
- Using an Op Amp to Drive a Simple and Practical Power Amplifier
- Simple LED advertising light circuit
- FL52C4 induction electronic greeter
- temperature controller circuit
- Digital display electric heating furnace automatic temperature controller
- Temperature controllable electric blanket temperature controller circuit
- Schematic diagram of thermistor temperature controller
- Thyristor zero-crossing switch temperature controller circuit
- heater temperature controller
- 555 temperature controller
- Temperature Controller
- simple temperature controller
