MULTI-BEAM Plus power connector, do you know it?
Source: InternetPublisher:消失的歌 Keywords: multi-beam power connector Updated: 2020/04/21
What is a MULTI-BEAM Plus power connector? What does it do? TE Connectivity (TE), a global leader in innovative connectivity solutions for high-speed computing and networking applications, announced the launch of the latest expansion of its highly recognized power connector product line - MULTI-BEAM Plus connector. The MULTI-BEAM Plus connector adopts the same slim design as its predecessor power connectors, MULTI-BEAM XL, MULTI-BEAM XLE and MULTI-BEAM HD, and offers the same ventilation performance.
MULTI-BEAM Plus connectors can carry up to 140A per power terminal, and each of the four adjacent power terminals can carry up to 100A, meeting the market demand for high-power solutions. In addition, the scalable, modular design of MULTI-BEAM Plus connectors improves configuration and PCB design flexibility.
The new MULTI-BEAM Plus power connector uses thickened materials and high-density solder legs to support higher current transmission, and its separate power terminal design improves product dimensional stability. MULTI-BEAM Plus connectors are suitable for data centers, telecommunications equipment, industrial automation equipment and power systems.
As an authorized distributor of TE, Heilind can provide relevant services and support to the market. In addition, Heilind also supplies products from many of the world's top manufacturers, covering 25 different component categories, and values all market segments and all customers. Constantly seeking a broad product offering to cover all markets. The above is the analysis of MULTI-BEAM Plus power connector, I hope it can help you.
- Practical and convenient fax machine power supply control circuit
- Driving circuit of switching power supply field effect tube
- Use pulse width modulation to get a precise output voltage
- Transformerless AC-DC constant current LED driver circuit
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- Parallel DC regulated power supply circuit diagram
- A novel and practical DC low voltage stabilized power supply
- 0.7~24V continuously adjustable current limiting power supply
- MAX1811 Lithium Battery Charger Production
- Homemade Electric Bike Fast Charger
- Power circuit with smoothing filter capacitor
- 3-phase CPU power circuit using HIP6301 and HIP6601 chips
- 500A-6V single-phase thyristor voltage regulating electroplating power supply circuit
- Warm current power circuit a
- Transistor stabilized current power supply circuit 2
- Additional power circuit design for USB devices
- Industrial four-way programmable controller power circuit
- Remote control TV doorbell power circuit
- Common power circuits and applications 01
- COMPAQ 420G type SVGA color display power supply circuit
