AD594 to 597 basic application circuit a
Source: InternetPublisher:风向双子座 Keywords: Application circuit AD BSP thermocouple Updated: 2020/10/11
The relationship between AD594/595 output and temperature is:
AD594: Vo=(Voj +16pLV) x193.4 (mV)
where: voJ is the output voltage of the J-type thermocouple .
AD595 :
Vo
(VOK +llIr,V) ) x180.57 (mV)
where: voJ is the output voltage of type J thermocouple.
AD597: Vo=VOK x245.46 (mV)
where: VOK is the output voltage of type K thermocouple.
③ Pin HYS adjusts the input and output Hysteresis.
The basic application circuit of AD594~597 is shown in the figure.
In the AD594/595 circuit, the thermocouple is directly connected to lC. When using a single +5v power supply, it is very convenient
to obtain vo=rxlOmV/C (r is the thermocouple The output of the temperature sensed by the couple), the temperature measurement range is O~+300qC;
in the basic application circuit of AD 596/597 , a hysteresis adjustment element R1-ink, RPi and temperature alarm indicator
LED are added, and RPi can be adjusted The hysteresis of the output voltage, for every 200 nA current increase in pin ③, the output will increase the temperature
hysteresis of 1°C. The output voltage is vo=rx lOmV gate C (r is the temperature of the thermocouple ), and the temperature measurement range is O-300C , the accuracy
is t0.020C (+25-+lOOoC).
- An article explains the working principle of the Wheatstone bridge
- Causes and solutions for noise in digital Class D amplifiers
- Datasheet/Pinout/Technical Specifications of LMC555
- How do you calculate the value of capacitors in series? Why use capacitors in series?
- How to calculate the value of capacitors in parallel?
- How to build a drag racing timer circuit using a 7-segment display and discrete components
- Share a Motorola amplifier circuit
- LED Bicycle Lights
- Digital number selection machine
- FL52C4 induction electronic greeter
- strain sensor
- AD8202 two-stage system structure application circuit diagram
- AD524 gain 200 amplifier
- AD524 pin and internal circuit function block diagram
- Basic application circuit of AD590d
- AD574 and PC bus interface circuit
- Charging circuit personal working principle diagram
- Principle circuit diagram of automatic converter for power outage emergency lights
- AD22057 amplifier circuit
- AD208 circuit functional block diagram
