Basic application circuit of AD590d
Source: InternetPublisher:傻阿乐 Keywords: Application circuit AD BSP temperature detection Updated: 2020/08/25
Shown is a basic application circuit for the AD590.
Since the AD590 is a current output, a series resistor can convert the output current into voltage. Figure 1-31 (a) is the most
basic application circuit . The output current of AD590 is in Zhan. , the voltage formed on RP is used as the output vo, and RP is used for output trimming.
For example, when Ri+RP=1. OK, at 25℃, the output vo=298. 15 bcA×lk0,=298. 15mV. Figure 1-31
(b) and (c) show the series and parallel applications of AD590 respectively. More than three of them can be connected in series or in parallel at the same time. AD590 series application can be used for multi-point temperature detection
in a small space ; Figure 1-31 (b) The output voltage
is based on the position of the AD590 with the lowest temperature, Figure 1-31 (c) The output voltage is the average of several AD590s, It can improve
the accuracy of multi-point temperature detection .
AD590 is very easy to interface with CMOS digital circuits. It can be connected to gate circuits, analog electronic switches, etc.
Figure 1-31 (d) is a circuit using a NOT gate as an electronic switch for multi-channel temperature detection . The output voltage is affected by Cl,
C2, C3 terminal control. For example, when cl -0, C2=1, C3 =1, the output is AD 590 -1.
- The unidirectional conduction current of the diode, the diode and its common uses
- How do Zener diodes protect circuits?
- How does sand become chips?
- FPGA Features and Architecture
- Why Do Amplifier Fuses Blow? How Do You Prevent Amplifier Fuses from Blowing?
- What is a D flip-flop and how does it work?
- Working principle/characteristics/application fields/equivalent circuit of unijunction transistor
- What types of force sensors are there?
- Purpose and composition of amplifier circuit: low frequency voltage amplifier amplifier circuit
- An example of proportional integral circuit diagram
- Motor overcurrent protection circuit
- AD524J type thermocouple cold junction compensation temperature measurement circuit
- Introduction to the high-precision ±5V reference source AD586
- Internal block diagram of ADP3000 integrated circuit
- Revolution or pitch counting circuit
- Battery charge controller ADP3810/3811 circuit
- Principle circuit diagram of automatic converter for power outage emergency lights
- AD693 type 4 to 20mA sensor transmitter circuit
- AD586 superposition circuit diagram
- AD7660 negative voltage and positive voltage doubler output circuit diagram
