Precision temperature measurement circuit designed with OP491
Source: InternetPublisher:笑流年 Keywords: Temperature measurement circuit BSP output voltage amplifier Updated: 2020/04/02
The basic parameters of OP491 are: voltage drift
700Lr,V, conversion rate 0.5V/an s, bandwidth 3MHZ, working
power supply range +2.7 to +12V. The precision temperature measurement circuit designed with OP491 is shown in Figure 1-11.
Rl, RTD and RP are bridge detection
circuits. AD589 is a 1.235V precision voltage source.
Together with Al, it forms a 200I.LA constant current source. The constant current
passes through RP and is evenly distributed to the two arms of the bridge.
When the bridge is balanced, the voltage between A and B is zero
(during debugging, use a 100.00n resistor instead of RTD and
adjust RPi so that the voltage between A and B is 0+oov
). When the temperature changes, the RTD resistance
changes and the bridge loses balance. The
output voltage VAB between A and B. A2 and A3 form an instrument amplifier
. When R = R8 and R6 = Rg, the output voltage of the amplifier
is vo = (1+R6/R7)VAB. According to the parameters in the figure, the gain of the amplifier is 274. Every time the temperature changes by
1℃, the output voltage changes by ImV.
- How do pull-up resistors work? How do I choose a pull-up resistor value?
- Which TVS diodes are suitable for RS232/RS485 and Controller Area Network applications?
- Types and structures/characteristics/functions/implementations of smart sensors
- What are the types of commonly used batteries?
- Working principle/characteristics/application fields/equivalent circuit of unijunction transistor
- Causes of PCB deformation How to prevent circuit board bending and warping
- How to build a drag racing timer circuit using a 7-segment display and discrete components
- Analysis of three simple electronic dice circuits
- Why use PWM? What are its advantages?
- What is a Demultiplexer
- High-efficiency speaker circuit for rural stage
- Egg warming circuit
- Rice mill circuit
- Straw returning to field crusher circuit
- ring amplitude modulation circuit
- Wien bridge oscillator circuit
- Schiller oscillator circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- Guest arrival signal recognition circuit
- Power phase sequence display circuit
