High-current high-efficiency switching regulated power supply composed of LAS6351
Source: InternetPublisher:明天见 Keywords: Switching regulated power supply BSP Updated: 2021/05/31
As shown in the figure, a high -current and high-efficiency switching regulated power supply composed of LAS6351 is shown . LAS6351 is a high current adjustable pulse width switching integrated voltage regulator with relatively complete functions. It can output a voltage in the range of 2.5 to 50V while withstanding a continuous load current of 3 to 8A; the chip is equipped with a soft start, overload and overvoltage protection and overheating shutdown protection circuit; the efficiency is as high as 90%; since the switching frequency is as high as 200kHz, the removes the cost of the external output LC filter. It can be used to directly assemble 15W, 25W, 40W adjustable or fixed switching regulated power supplies. The circuit shown in the picture is a +5V, 5A switching regulated power supply.
![Large<strong>Current</strong>High Efficiency<strong>Switching Regulated Power Supply</strong> composed of LAS6351](http://www.eeworld.com.cn/circuit/upload/13919645e47d592826146686ed74bec3/3eaded6785f7fc0641dda5348aff1d4c.jpg)
- In-depth analysis of DC-AC converter inverter
- Driving circuit of switching power supply field effect tube
- Basic circuit description of adjustable voltage regulator LM317
- LED rechargeable flashlight circuit diagram
- Current/voltage conversion circuit using current converter
- Miniature polarity reversal power supply using MAX1721
- Boost drive circuit composed of RT8450
- Adjustable voltage regulated power supply circuit
- Practical constant current charger-----Constant current charger
- MAX1811 Lithium Battery Charger Production
- Smoking Cessation Circuit
- Egg warming circuit
- Agricultural small tractor lighting circuit
- Mixer built with analog multipliers
- Varactor Diode Frequency Modulator
- base amplitude modulation circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Second-order active band-stop filter circuit
- Digital stopwatch display circuit
- Sawtooth wave generator circuit (1)
