Do you know about the BLE wall switch that does not require a neutral wire connection?
Source: InternetPublisher:王达业 Keywords: ble zero line Updated: 2020/02/25
What is a BLE wall switch that requires no neutral connection? What does it do? Power Integrations has released a new design example report (DER-832) - this single FireWire Bluetooth Low Energy (BLE) smart wall switch requires no neutral wire Connected, capable of powering 3 W to 600 W LED/fluorescent/incandescent bulbs.
The design is based on PI's high-efficiency LinkSwitch-TN2 offline switching power supply IC, which has ultra-low current consumption and can make the system leakage current less than 100 µA at 230 VAC.
Regular smart wall switches require a third wire (neutral) to prevent ghosting or flickering caused by leakage current in standby mode, but most residential wall switches only have two wires.
LinkSwitch-TN2, used in conjunction with a unique current shaping circuit, provides an ideal solution for zero-wire wiring of multi-functional smart wall switches. The above is the analysis of BLE wall switch that does not require neutral wire connection. I hope it can be helpful to everyone.
- How to Make a Soft Latch Circuit
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Recommended circuits for different power on times of LM4911
- Use pulse width modulation to get a precise output voltage
- Transformerless AC-DC constant current LED driver circuit
- The constant current source composed of two transistors can drive high power
- Detailed explanation of 5v charger circuit diagram
- Charging control circuit made by solar energy
- Integrated regulated power supply with continuously adjustable output voltage
- Car power 1.5V-12V six-speed converter
- DC 12V to AC 100V inverter power supply circuit design
- Power supply circuit design optimized for digital light projectors
- High current (4A) switching regulator integrated circuit L296 outputs 5.1 to 40V
- Power supply circuit with multiple outputs (MAX1902)
- 3-phase CPU power circuit using HIP6301 and HIP6601 chips
- FGDF-3 three-phase low-temperature iron-plated power supply circuit
- Warm current power supply circuit b
- audio power circuit
- COMPAQ 420G type SVGA color display power supply circuit
- CTX-C2 dual-band high-resolution color display power circuit
