Instantaneous water heater automatic constant temperature experimental circuit diagram
Source: InternetPublisher:张小哥 Keywords: Water heater circuit diagram experimental circuit switch Updated: 2021/06/01
I have been using the instantaneous water heater at home for many years, but every time I take a bath, I feel troubled. The water temperature control of the water heater is divided into 9 levels. The larger the number from 1 to 9, the higher the temperature. It should be easy to use. However, the water flow can also control the water temperature, and often causes the temperature to be out of control. For example, the water pressure decreases and the water volume becomes smaller. The heat cannot be taken away by the water immediately. The temperature (protection) switch inside the water heater will activate and you will be scalded. It is very uncomfortable to be tortured by cold water after a while.
In order to change this situation, I added a simple temperature control circuit, which can control the heating time of the original circuit, that is, the duty cycle. The effect is satisfactory, especially the temperature (protection) switch inside the water heater never operates again, which is very comfortable. .
The temperature sensor in the circuit uses an old-fashioned thermistor. Since the resistance is a bit small, a germanium diode is added for this purpose.
The main components used in the water heater circuit are: ULN2003AN, 7805/7812, BTA41600B, JQX-15F, HMS87C1202A, MOC3021.
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- A very convenient small power supply circuit to share
- In-depth analysis of DC-AC converter inverter
- Step-down power supply for driving relays
- What kind of circuit is a voltage regulator circuit?
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Switching power supply circuit composition and function introduction of each part
- How to use SBR to improve power conversion efficiency
- 3~15V 10A adjustable voltage regulated power supply
- USB power socket using the car battery
- The service life of some components of the switching power supply
- Principle circuit of current switching class D amplifier
- Paper tension control circuit
- On and off states generate fixed-width pulse circuit
- Contactless switch conversion circuit a
- Anti-shake circuit using RS flip-flop
- Temperature detection control circuit of electric kettle
- Geographical structure of split-phase starting single-phase induction motor
- Single pulse signal generating circuit e
- Lithium battery charger circuit
