Auxiliary audio power amplifier circuit design based on LM4730
Source: InternetPublisher:狂妄火龙果 Keywords: Circuit design audio power amplifier power amplifier circuit Updated: 2021/01/10
![Auxiliary audio power amplifier circuit design based on LM4730](http://www.eeworld.com.cn/circuit/upload/7773e7855de5031f9c78615f7e5b8e89/57e77c1b761980b1aa7734a8e27fd94a.jpg)
Circuit principle: The picture shows the auxiliary audio power amplifier circuit of LM 4730 . The audio input signal passes through the potentiometers Rv, CIN, and RB and then is added to the input terminal 8 of the LM 4730. After amplification, it is output by pin 3 and sent to the speaker through L and R (the number in the parentheses is the B pin number of the internal amplifier). Rv is the volume potentiometer, used to adjust the volume; RIN is to set the DC bias working point of the amplifier, and forms an input high-pass filter with CIN; RSN and CSN are used to reduce the instability of the high-end frequency of the amplifier; L, R It provides high impedance for high frequencies and low impedance channel for audio to prevent high frequency self-excitation.
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- Build a simple buck-boost regulator and test it on a breadboard
- Benefits of Wide Bandgap Technology for Power Converters
- LED Driver ZD1680
- Detailed explanation of 5v charger circuit diagram
- Miniature polarity reversal power supply using MAX1721
- An ultra-low output voltage regulator
- 0.7~24V continuously adjustable current limiting power supply
- Mc34063 MP3 Switching Charger
- A low-cost, high-reliability battery charger for electric vehicles
- DC 12V to AC 100V inverter power supply circuit design
- Audio power amplifier circuit using TDA2006 chip
- Audio power amplifier circuit using TDA8563Q chip
- BTL power amplifier circuit
- Integrated OTL power amplifier circuit composed of TDA2040
- 3-phase CPU power circuit using HIP6301 and HIP6601 chips
- 2-phase CPU power supply circuit using HIP6302 and HIP6602 chips
- OTLC power amplifier circuit
- A757 power amplifier circuit
- New dual loop power amplifier
