New dual loop power amplifier
Source: InternetPublisher:国民男神经 Keywords: power amplifier potential power amplifier circuit Updated: 2020/12/14
In the signal power amplifier circuit composed of VT1, VT2, VT5~VT11, etc.,
appropriate local negative feedback is added to each stage, a large loop negative feedback capacitor is used, and a transistor with a high characteristic frequency is selected to reduce
the transient interaction. Adjust distortion, improve transient response, widen the passband and reduce the startup impact sound. The notable feature of this power amplifier is
that
VT3, VT4 and VT5-VT11 form another DC negative feedback amplification circuit and the above signal power amplification circuit .
Simple forms are combined to form two closed loops 6 that are interconnected in structure and have independent working processes. This is the so-called
"double loop" power amplifier. The two loops work together to make the output of the amplifier static DC zero potential. Very
stable. If the output DC potential Uo rises for some reason, Uo can be reduced to Ov through feedback and DC amplification.
C3 and C4 in the circuit are used to filter out the AC component in the feedback signal , so that the loop where VT3 and VT4 are located has no AC negative feedback effect .
C2 can balance the bases of the two tubes VT3 and VT4 with the ground, reducing the noise of the switch.
- Convenient and fast power line break detection circuit
- DIY Multimeter High Frequency Signal Probe
- Simple electric tachometer
- Level measurement circuit composed of AD737
- Application of TDA1514
- Fluorescent tube inverter circuit and emergency lighting circuit 02
- AC equivalent amplifier circuit
- Directly coupled push-pull power amplifier circuit
- High Performance Digitally Controlled Amplifier-Gain Divider
- High-speed gain programmable amplifier circuit
- TDA7241 power amplifier circuit diagram
- TDA7233D power amplifier circuit diagram
- TDA7056A power amplifier circuit diagram
- TDA2008 power amplifier circuit diagram
- TDA1701 power amplifier circuit diagram
- TDA1519A power amplifier circuit diagram
- TBA810S power amplifier circuit diagram
- TA7769P power amplifier circuit diagram
- TMOS application circuit
- 120W power amplifier with detailed treble
