Typical Data Acquisition System Basic Grounding and Coupling Circuit (AD684/AD674)
Source: InternetPublisher:newrudeman Keywords: Data collection Updated: 2025/05/13
As shown in the figure, the basic grounding and coupling circuit of a typical data acquisition system. As any high-speed, high-resolution data acquisition system, the power supply must be well regulated, and the additional high-frequency noise (ripple) must be suppressed. The AD684 power supply connection can well meet the above requirements, while being able to transmit instantaneous current to the device. In order to achieve the rated accuracy and dynamic performance, the power supply decoupling capacitor must be directly connected between the positive and negative legs of the power supply to the ground. Typically, a 0.1μF ceramic capacitor is used to connect VCC and VEE to the ground.
- 1.2-36V 5A Adjustable Power Supply (Based on LM317)
- Vehicle-mounted 12V to 50V DC converter
- LM317 Adjustable Regulated Power Supply
- Charging monitor for 12V lead-acid batteries
- 1.5V to 5V/12V DC/DC converter based on LT1073
- DC 13.8V to DC 250V inverter circuit
- Charge-coupled bidirectional power MOSFET relay
- Mitigating Overheating in Hyperscale and Ultra-Scale FPGA Applications
- When debugging a boost converter, you can analyze it from four directions.
- Power Converter Topology Component Selection for High Input Voltage Applications
- Switching power supply circuit composition and detailed explanation of each part (1)
- Portable device charging power circuit design
- Dual adjustable power circuit
- 3v to 5v circuit diagram
- Commonly used power circuits in printers
- Single LTC power circuit
- Household emergency power circuit 02
- Common power circuits and applications 03
- 5V uninterruptible power supply circuit
京公网安备 11010802033920号
