Efficient electronic mouse trap circuit
Source: InternetPublisher:桂花蒸 Keywords: Grid BSP Updated: 2021/07/11
Shown is a simple and efficient electronic mousetrap circuit
. The red and black terminals are connected to the metal grid respectively, and the gap between the grids
is 2cm. When a mouse comes into contact with the energized grid , it will be knocked down and
an alarm signal will sound from the speaker. At this time, you can disconnect the power supply and
kill the rats to achieve the purpose of eradicating rats.
When using this kind of electronic mousetrap, a special person must be on duty
and special attention should be paid to personal safety. A fence must be set up. When people approach,
the power must be disconnected first.
- Hot wire spark plug control circuit
- Mono LB1405 level indication circuit
- Telephone line protection alarm circuit
- One control two constant pressure water supply frequency conversion speed control circuit b
- JC3.5 hydraulic controller and its wiring a
- Catillac luggage compartment closing circuit diagram
- Smart transmitter circuit diagram with hart interface
- HTS fire alarm
- Cadillac reversing light circuit diagram
- One use and one standby constant pressure water supply frequency conversion speed control circuit b
- Smoking Cessation Circuit
- Homemade disinfectant circuit
- Fish pond oxygenation reminder circuit
- Greenhouse temperature control circuit
- Amplitude modulation circuit composed of MC1496
- Parallel crystal oscillator
- Second-order active band-stop filter circuit
- Voltage controlled power supply second-order high-pass filter circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Power phase sequence display circuit
