Ultrasonic remote control circuit b composed of T-40-16
Source: InternetPublisher:石榴姐 Keywords: Ultrasonic remote control circuit BSP transmitter Updated: 2020/08/31
The ultrasonic transmitter circuit composed of T-40-16 and 555
is shown in Figure 18-3 2a. The circuit is composed of ultrasonic transmitter T-40-16 and 555 circuits. The oscillation frequency of the circuit can be changed by adjusting the potentiometer RP
. The 40kHz oscillation pulse output from pin 3 of the 555 drives the T-40-16 to work, causing it to emit a 40kHz ultrasonic signal. The working voltage of the circuit
is 9V, and the working current is 40-45mA. The control distance is greater than 8m.
(2) The R-40-16 ultrasonic wave receiving circuit
is shown in Figure 18-32b. The circuit consists of VT1-VT7 and other components. Since the signal received from the transmitter is very weak, the circuit uses
multi-stage amplification to output a square pulse signal, which is connected to VT5: VT6 and related components to form a bistable circuit. i. The transistor
VT4 is turned on every time Once ( the transmitter transmits once), the trigger signal sends a trigger pulse to the bistable circuit via G and C. VT5:''VT6
reverses once. When VT6 changes from cut-off to on, VT5 and VT7 cut off, and relay K releases and holds. When the next pulse arrives
- VT6 turns on and turns off. VT7 is turned on and relay K is closed to control the load operation. This circuit can be used for remote
control of various electrical switches .
- How to use FPGA and RS485 for industrial communication
- The main characteristics, advantages and disadvantages of IoT protocols
- Convenient and practical multifunctional wireless nursing assistance device
- Making an FM receiver with a high-frequency head
- Wireless doorbell production
- RX3408 FM/FSK 500~20 MHz Receiver
- DKl000R OOK 315 MHz Receiver Module
- Radio coding transmission circuit composed of MICRF102 and PT2262
- MICRF500 FSK 1000~700 MHz Transceiver
- Stereo FM transmitter circuit designed with BH1417
- Excellent performance household inverter power supply circuit
- Self-defense anti-riot circuit
- Smoking Cessation Circuit
- Peanut and melon seeds roasting machine circuit
- Agricultural small tractor lighting circuit
- Particle clogging alarm circuit of wheat seeder
- Junction field effect transistor mixer circuit
- collector amplitude modulation circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Voltage-controlled voltage source second-order active low-pass filter circuit
