MCl3175/MCl3176 FM/AM 928~902 MHz/470~260 MHz Transmitter
Source: InternetPublisher:明天见 Keywords: Transmitter Updated: 2024/09/24
MCl3175/13176 is a monolithic transmitter chip designed for FM/AM communication systems, compliant with FCC Title47: Part 15. MCl3175/13176 can also be used as the oscillator source of the local oscillator in UHF and 900 MHz receivers, UHF and 900 MHz video transmitters, RF local area networks (LANs) and high-frequency clock drivers.
The main technical features are as follows:
・Use the third harmonic or fundamental crystal as the reference;
・Operating in the 260~470 MHz and 902~928 MHz frequency bands;
・The output frequency of MCl3175 is f=8×fref, the output frequency of MCl3176 is f=32×fref
・ASK/OOK modulation;
・Power supply current (transmit mode) is 34 mA, low power mode current is 0.5 uA;
・Adjustable power output (up to 10 dBm);
・The power output is differential, and can be output using a loop antenna or balanced or unbalanced transformers.
MC13176D 320 MHz FM Transmitter Circuit
MCl3176D 320 MHz NBFM transmitter circuit
MCl3175/13176 320 MHz ASK Transmitter Circuit
- Why does CAN FD communication need to enable TDC for sending and receiving delay compensation? How to configure TDC and SSP in TCAN4550?
- How to Build a Simple FM Radio Receiver on a Breadboard
- Homemade modified machine with 4 LNB inputs and audio and video outputs
- Production of a FM wireless microphone
- MICRF011 00K 440~300 MHz Receiver/Data Demodulator
- RF2919 ASK/OOK 915/868/433 MHz Receiver
- TX4930 FM/FSK 915/868/433 MHz Transmitter
- TX500 ASK 1 GHz~100 MHz Transmitter Module
- DKIOOOT OOK 315 MHz Transmitter Module
- MICRF500 FSK 1000~700 MHz Transceiver
- Transmitter circuit and PT2262-IR encoding waveform diagram
- USB communication circuit
- Infrared anti-theft alarm circuit 3b
- Use HS101 and 201 to make a four-channel radio remote control switch
- Infrared remote control light switch
- Object departure alarm circuit
- transmitter toy circuit
- Wireless remote control transmitter lighting circuit
- model rocket launcher
- TV game console infrared remote control transmitter
