desk lamp remote control circuit
Source: InternetPublisher:天天都吃好吃的 Keywords: Remote control circuit BSP Updated: 2020/08/05
The 220V AC voltage is stepped down by the capacitor C], the rectifier bridge stack UR performs barrier wave rectification,
the capacitor Cz filters, and the voltage is stabilized by the Zener diode and becomes a DC voltage. '
The resistance of the photoresistor RG is very small during the day, and the pulse signal charging the capacitor C3 is very small, which cannot trigger the thyristor to conduct, the EL circuit of the bulb
is blocked, and the bulb F:I_ does not light up; when night falls, the dark resistance of the photoresistor is very large, The charging pulse signal to capacitor
C3 is very large, which can trigger
the gate of the thyristor, causing the thyristor to conduct. At this time, the relay coil is energized, and the normally open contact of the relay in the EL circuit of the light bulb is connected, and the light bulb EI
lights up . .
Adjusting the potentiometer RP can adjust the size of the trigger signal to the gate, thereby adjusting the conduction angle of the thyristor, thereby controlling the brightness of the bulb
- Share the features of Wi-Fi 6 that you don’t know
- LM386 makes an AM radio
- S9018 single tube super regenerative FM receiving circuit
- AM Transmitter
- Convenient and practical telephone automatic redial controller
- RXM-900-HP-II FM/FSK 928~902 MHz Receiver Module
- rfRXD0920 ASK/FSK/FM 930~800 MHz Receiver
- TQ5638 KPCS CDMA/GPS 2090 ~ 1620 MHz Dual Mode Receiver
- DKIOOOT OOK 315 MHz Transmitter Module
- RCV420 4~20mA Precision Current Loop Receiver
- Voice controlled flash LED light circuit diagram
- Self-defense anti-riot circuit
- Physiotherapy ventilator circuit
- Egg warming circuit
- Farmland drainage automatic control circuit
- AC voltmeter
- Amplitude modulation circuit composed of MC1496
- Second-order active band-stop filter circuit
- color discrimination circuit
- Guest arrival signal recognition circuit
