MAX2820/MAX2821 I/Q 2.5-2.4 GHz Transceivers
Source: InternetPublisher:天天都吃好吃的 Keywords: Transceiver Updated: 2024/09/24
The MAX2820/MAX2821 are transceivers designed for applications operating in 802.1lb (11 Mb/s). The MAX2821 provides a shutdown mode and an analog reference voltage output. The MAX2820/MAX2821 are suitable for 802.1lb ll Mb/s WLAN, 802.1lb 22 Mb/s PBCC high-data-rate WLAN, 802.1la b dual-channel WLAN, and 2.4GHz ISM band radio applications.
The main technical features are as follows:
・Operating in 2.4~2.5 GHz ISM band;
・CCK modulation method;
・802.1lb (11 Mb/s CCK and 22 Mb/s PBCC) PHY compatible;
・The transmission power control range is greater than 25 dB;
・Receive AGC control range greater than 65 dB;
・Receiver sensitivity is -97dBm (at 11 Mb/s);
・Transmit power is 2 dBm (11 Mb/s CCK);
・Power supply voltage is 2.7 to 3.6 V;
・Direct up-conversion and down-conversion to complete RF to baseband conversion;
・On-chip baseband low-pass filter is shared by both transmit and receive.
Application circuit diagram of MAX2820/MAX2821
- How to Build a Simple FM Radio Receiver on a Breadboard
- Application of GaN power devices in array radar transceiver systems
- Design and Analysis of Half-duplex Intercom Circuit Using LM386
- MAX2360/MAX2362/MAX2364 I/Q 2000~1700 MHz/1000~800 MHz dual-band
- MICRF011 00K 440~300 MHz Receiver/Data Demodulator
- MAX23691/Q 2000-800 MHz Dual-Band Tri-Mode Transmitter
- WE800 FM/FSK 1~0.1 GHz Transmitter
- RF2948B QPSK 2.4 GHz Spread Spectrum Transceiver
- RF2919 ASK/OOK 915/868/433 MHz Receiver
- TR5100 FM 150~15 MHz transceiver
- Integrated RF sampling transceiver, do you know?
- 16-port 50GbE PHY transceiver, do you know it?
- TI TCAN4550 system basic chip analysis
- Fiber optic transceiver circuit diagram
- USB communication circuit
- Indoor unit communication circuit
- Ultra-low power transceiver network circuit with RS485 performance
- Long distance serial communication circuit
- Computer wireless data transceiver circuit diagram
- CAN bus communication circuit
