TX500 ASK 1 GHz~100 MHz Transmitter Module
Source: InternetPublisher:赔钱虎 Keywords: Transmitter Updated: 2024/09/19
TX500 is an ASK wireless data transmitter module. It uses PLL frequency stabilization technology and is widely used in small area wireless data communications, such as wireless meter reading systems. The main technical features are as follows: ・The operating frequency is 100 MHz~1 GHz; ・The center frequency error is ±5×10-6 (TA=25℃); ・ASK modulation method; ・The modulation speed is DC~-100 kHz (50% duty cycle square wave, TTL signal); ・Point-to-point communication method, used in conjunction with RXl00 or RX500; ・The data interface is through a through-hole capacitor, the antenna interface uses Q9, and the input signal interface uses TTL/CMOS or RS-232; ・The maximum data rate is 100 Kb/s; ・The operating voltage is 12~15 V; ・The operating current is 170 mA (at 12 V), and the standby current is less than 10 uA; ・The radiated power (continuous wave) is 27 dB; ・ ・Transmission distance: In open areas, the antenna is 1.5 m above the ground, which is about 1.5 km; in open areas, the transmitting antenna is 30 m above the ground, which is about 2 km. In general urban environments, the antenna is 1.5 m above the ground, which is about 1 km. km, ・The operating temperature is -40~85℃(-10~60℃ is recommended).
Application circuit of TX500
- Share the features of Wi-Fi 6 that you don’t know
- How to Build a Simple FM Radio Receiver on a Breadboard
- Pocket Wireless Microphone
- 1W FM Broadcast Transmitter
- MICRF011 00K 440~300 MHz Receiver/Data Demodulator
- MAX2366/MAX2367/MAX2368 I/Q 2000-1700 MHz/1000-800 MHz dual-band
- MICRFl03 ASK 1 GHz~800 MHz Transmitter
- T5761/T5760 ASK/FSK 870~868 MHz/928~902 MHz Receiver
- RF2516 AM/ASK/OOK 433/315 MHz Transmitter
- F05A/B/C Series AM 433/315 MHz RF Transmitter Module
- Transmitter circuit and PT2262-IR encoding waveform diagram
- USB communication circuit
- Infrared anti-theft alarm circuit 3b
- Use HS101 and 201 to make a four-channel radio remote control switch
- Infrared remote control light switch
- Object departure alarm circuit
- transmitter toy circuit
- Wireless remote control transmitter lighting circuit
- model rocket launcher
- TV game console infrared remote control transmitter
