Positive and negative DC regulated power supply circuit
Source: InternetPublisher:石榴姐 Keywords: DC regulated power supply regulated power supply circuit BSP filter capacitor Updated: 2020/08/16
Using a power supply circuit with integrated positive and negative voltage regulators, the secondary side output voltage of the transformer is 24V. The output DC voltage after full-wave rectification
is 24VXo. 9- 21. 6V. The two 1000_uF
capacitors are the filter capacitors of the two bridge rectifier circuits .
After being stabilized by the integrated voltage regulator, positive and negative 15V
DC power supplies are output respectively.
The internal voltage stabilization system and ripple elimination system of the integrated voltage regulator
are very complete, so the filter capacitor does not need to be too large. In particular,
the currently widely used voice-activated light switches are all powered by this power
supply.
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Basic connection circuit of signal and power supply composed of ISOll3
- Single-power supply circuit for ISO122P/ISO124
- Transformerless AC-DC constant current LED driver circuit
- Switching power supply circuit composition and function introduction of each part
- Boost drive circuit composed of RT8450
- Dynamic power supply for power amplifier controlled by thyristor
- Power supply circuit that can reduce LM317 ripple
- MIC4680 constant current charger
- MAX1811 Lithium Battery Charger Production
- Motor forward and reverse control wiring diagram (2)
- Voice controlled flash LED light circuit diagram
- Electronic thermometer circuit
- Crop anti-frost circuit
- Chicken supplementary light to increase egg production rate circuit
- Rural fish farming control circuit
- Junction field effect transistor mixer circuit
- Frequency modulator composed of NE566
- Schiller oscillator circuit
- Three primary color display circuit
