Three-terminal fixed voltage stabilized power supply circuit
Source: InternetPublisher:王达业 Keywords: Stabilized power supply circuit BSP transformer stabilized power supply Updated: 2020/05/24
The three-terminal voltage-stabilized power supply consists of a transformer T, a rectifier bridge VD1~VD4, a filter capacitor Ct and a j-terminal fixed voltage stabilizing integrated block.
The output voltage is fixed at 15V and cannot be adjusted, as shown in the figure.
The input and output voltage and other parameters of different voltage stabilizing blocks are different
, so readers must pay attention when selecting them.
The parameters of several different voltage stabilizing blocks are shown in the table.
- 220V Remote Load Monitor
- Using Lead-acid Battery as Power Source for Walkman
- What kind of circuit is a voltage regulator circuit?
- Basic connection circuit of signal and power supply composed of ISOll3
- Single-power supply circuit for ISO122P/ISO124
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- Constant current LED lamp driver circuit with soft start and anti-shock
- LED rechargeable flashlight circuit diagram
- CNC regulated power supply production
- LM317T voltage regulation adjustable circuit diagram explanation
- electromagnetic field sensor
- strain sensor
- stuttering correction circuit
- Agricultural spraying and insecticide control circuit
- base amplitude modulation circuit
- Wien bridge oscillator circuit
- Capacitive feedback oscillator circuit
- Differential Amplifier Circuit
- Voltage series negative feedback amplifier circuit
- Small current generator circuit
