Parallel DC regulated power supply circuit
Source: InternetPublisher:风向双子座 Keywords: DC regulated power supply regulated power supply circuit BSP Updated: 2021/06/03
The DC power supply adopts a parallel type. After rectification, filtering, current limiting and voltage stabilization, it outputs a voltage of ±10V respectively. The circuit is simple and low-cost, and can
meet the requirements of various applications, as shown in the figure.
In the figure 6. 3V indicator lights EL1 and EL2 respectively indicate the running and stopping status of the machine tool, and are controlled by the relay control circuit.
- Build a simple buck-boost regulator and test it on a breadboard
- Fabrication of multi-cell lithium battery charging circuit
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- LED rechargeable flashlight circuit diagram
- Dynamic power supply for power amplifier controlled by thyristor
- Power supply circuit that can reduce LM317 ripple
- 3~15V 10A adjustable voltage regulated power supply
- Car power 1.5V-12V six-speed converter
- USB power socket using the car battery
- Production of backup power supply for cordless phone
- Motor forward and reverse control wiring diagram (2)
- Analysis of rectifier circuit types and principles
- Egg warming circuit
- Egg heating control circuit
- Frequency modulator composed of NE566
- Parallel crystal oscillator
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Double gate field effect transistor high frequency amplifier circuit
- High and low frequency signal generator circuit
- Motorcycle flash light circuit
