Sawtooth wave phase shift trigger circuit
Source: InternetPublisher:aerobotics Keywords: Trigger circuit phase-shift trigger sawtooth wave Updated: 2021/02/12
The sawtooth wave phase-shifting trigger circuit is composed of PNP tubes, and the synchronous phase-shifting circuit is composed of transistor VT1 and capacitor C. Constant current charging is performed to form a negative sawtooth transition
voltage , which is superimposed with the negative control voltage ‰ (adjusted by RP2) and the positive offset voltage Ub (adjusted by RP4) through R3, R, and Rs.
The control transistor VT2 changes from cutoff to switching. is the moment of conduction. The circuit principle is as shown in the figure
- Recommended circuits for different power on times of LM4911
- Low cost and high performance LED constant current power supply
- Integrated regulated power supply with continuously adjustable output voltage
- CNC regulated power supply production
- 3~15V 10A adjustable voltage regulated power supply
- Electric bicycle battery charger circuit
- Design of electric vehicle charger
- UC3842 Electric Vehicle Charger
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Circuit diagram explanation: simple switching power supply circuit diagram
- STR5412 power circuit
- Typical Reference Voltage and Power Supply Circuits
- EPSON PHOTO 830U printer power circuit
- Voltage stabilization control circuit in power circuit
- Output 12V-10A power supply circuit
- High current (4A) switching regulator integrated circuit L296 outputs 5.1 to 40V
- 3-phase CPU power circuit using HIP6301 and HIP6601 chips
- Warm current power supply circuit b
- Nine-speed adjustable DC power circuit
- Maintenance and experiment of multi-purpose power circuits
