1880MHz internal collector bias amplifier application circuit composed of RF2324
Source: InternetPublisher:蓝猫淘气 Keywords: Amplifier Updated: 2024/09/14
As shown in the figure, this is the 1880MHz internal collector bias amplifier application circuit composed of RF2324. The RF signal (RF) is input from pin 3 and output from pin 7 after being amplified by the preamplifier and the final power amplifier. Pin 3 is directly coupled to the internal amplifier, so a 10pF DC-blocking coupling capacitor is added externally, and the matching impedance is 50Ω when working at 1880MHz. Pin 7 is the open collector output terminal, which can be connected to the power supply VCC through a choke or matching inductor. The typical matching impedance of this pin is 50Ω. The external output matching network matches the amplifier output impedance to it to obtain the maximum output power and efficiency. Pin 1 is the power reduction control terminal. When VPD=2.8V±0.1V (IPD typical value is 8.5mA), the circuit works; when VPD<0.9V, the circuit is turned off. VPD requires an external RF bypass circuit.
- How do pull-up resistors work? How do I choose a pull-up resistor value?
- Analysis of the flow direction of transistor current
- How to read resistor color codes? Resistor color codes illustrated
- What is the difference between CPLD and FPGA?
- How to Build a Simple Temperature Indicator Circuit Using NTC and PTC Thermistors
- How to build a triangle wave generator using an op amp and discrete components
- How to install the accelerometer
- Using an Op Amp to Drive a Simple and Practical Power Amplifier
- Touch circuit design and analysis
- Simple LED advertising light circuit
- Op amp driving LEDs
- Sense amplifier circuit
- Ultrasonic proximity sensor circuit
- Operational amplifier negative feedback circuit diagram
- variable gain amplifier
- An FM transmitter overvoltage protection circuit diagram
- intercom circuit
- Inventory of radio frequency interference rectification error circuits in amplifiers
- Pressure sensor measurement circuit
- Pressure measurement circuit diagram
