FET buffer amplifier with high input impedance using INA103
Source: InternetPublisher:红水杯 Keywords: Amplifier Updated: 2024/09/13
As shown in the figure, it is a FET buffer amplifier with high input impedance. This circuit uses the FET high impedance characteristics of the internal input stage of OPA627, and uses two OPA627s to form an emitter follower as a buffer amplifier for the circuit input, so it has extremely high input impedance and the circuit gain is 100.
- The unidirectional conduction current of the diode, the diode and its common uses
- What is a Half Wave Rectifier? Working Principle of a Half Wave Rectifier
- What is the relationship between capacitance and impedance in an AC circuit? How do you calculate the impedance of a capacitor?
- The Importance and Ideal Model of Impedance Matching
- What types of power field effect tubes are there? Selection criteria for power field effect tubes
- Simple Wired Spy Bug Circuit Built Based on IC741
- Working principle/advantages/disadvantages/size of optical fiber
- How to Build a Simple Temperature Indicator Circuit Using NTC and PTC Thermistors
- How to build a drag racing timer circuit using a 7-segment display and discrete components
- Analysis of three simple electronic dice circuits
- Ultrasonic proximity sensor circuit
- High input impedance three op amp differential amplifier circuit diagram
- Differential bridge amplifier circuit diagram
- Low drift peak detector
- Op amp impedance multiplication circuit
- Variable gain operational amplifier circuit diagram
- A crystal controlled local oscillator circuit diagram
- variable gain amplifier
- Inventory of radio frequency interference rectification error circuits in amplifiers
