Current feedback amplifier circuit of broadband transconductance operational amplifier and buffer OPA660
Source: InternetPublisher:zht24 Keywords: Buffer amplifier circuit Updated: 2024/09/12
As shown in the figure, this is the current feedback amplifier circuit of OPA660. Signal V1 is input to pin 3 of OPA660 through a 47Ω resistor, amplified by internal amplifier 1 and output from pin 6; at the same time, pin 6 is fed back to pin 2 of OPA660 through a 200Ω resistor, forming a current feedback amplifier. The current feedback amplifier can stabilize the static operating point, widen the bandwidth, and reduce the amplifier output distortion. The circuit gain G=1 R4/R5=10.
- Voltage divider circuit calculation formula, where to find the voltage divider circuit?
- How are diodes made using semiconductors?
- Analysis of the flow direction of transistor current
- Which one is better, NPN or PNP transistor?
- What is the relationship between capacitance and impedance in an AC circuit? How do you calculate the impedance of a capacitor?
- The Importance and Ideal Model of Impedance Matching
- What are the main types of resistors? Detailed explanation of the functions and uses of resistors
- How to calculate the value of capacitors in parallel?
- Tutorial on building a NOT gate using BJT transistors
- What is the difference between JFET and MOSFET
- Seven basic analog circuits
- Single tuned amplifier circuit
- Current amplifier circuit structure diagram
- Practical amplifier circuit c composed of operational amplifier LM386
- Practical amplifier circuit consisting of operational amplifier LM386 e
- Adopting negative feedback broadband amplifier circuit
- Multistage DC coupled amplifier circuitb
- Two-stage DC-coupled amplifier circuit
- CD1140CP (audio and FM receiver) FM IF amplifier circuit
- Infrared remote control amplifier circuit using U250B
