LM4902 audio power amplifier circuit
Source: InternetPublisher:sigma Keywords: Audio Power Amplifier Updated: 2024/09/11
As shown in the figure, this is the LM4902 audio power amplifier circuit (MSOP package). After the audio signal is input, it is coupled to the inverting input terminal (pin 4) of the amplifier through Ci and Ri, while the non-inverting input terminal (pin 3) of the amplifier is connected to ground through CB. After power amplification, it is added to the speaker in the form of a bridge output from Vo1 (pin 5) and Vo2 (pin 8). There are two amplifiers inside the LM4902. The gain of the first amplifier is determined by the ratio of the external resistors RF and Ri, and the gain of the second amplifier is fixed to 1 by two internal 10kΩ resistors. When the Shutdown pin (pin 1) is at a logic low level, the amplifier is micro-powered off, and when it is at a logic high level, the amplifier works at full power.
- 6P3P parallel 20W power amplifier experiment
- A high-quality tube amplifier with 6P3P design
- Sugon New Tube 2A3C Single-ended Tube Amplifier
- Toy electronic chicken
- Homemade multi-sound effects sound system
- The production of 6P14 small tube amplifier
- Dual power supply audio power amplifier circuit using LM1875
- Minimum output noise/reduced output power circuit using LM4910
- Typical application circuit of LM4903/4905 audio power amplifier
- 2W×2 power amplifier circuit using LM1877
- Audio power amplifier circuit using MAX9789A and MAX9713 chips
- Auxiliary audio power amplifier circuit design based on LM4730
- 8W audio power amplifier circuit
- Two-channel high-fidelity power amplifier integrated circuit
- Audio power amplifier circuit using TDA8563Q chip
- Mono audio power amplifier circuit
- BTL audio power amplifier integrated circuit
- OTL audio power amplifier circuit
- 9W audio power amplifier (μPC2002) circuit diagram
- LM378 two-channel audio power amplifier circuit with adjustment circuit
