Inductance measuring instrument circuit
Source: InternetPublisher:拳制龙 Keywords: Measuring instrument inductance measurement BSP Updated: 2021/01/02
The bridge principle circuit for measuring low-Q inductors is shown below. This bridge circuit is also called the Maxwell
electric car.
In the inductor bridge circuit introduced above, the inductance is measured using a standard capacitor for comparison, and
its opposite arms are resistors. According to the basic principles of the AC bridge, if two adjacent arms are chosen to be pure resistors
, then the other two adjacent arms need to have the same impedance. In other words,
a standard place it in the phase of the measured inductor. A bridge circuit adjacent to the arm to measure the inductance. However, there are two inductance components in this bridge
circuit , which are prone to mutual inductance effects, and the measurement accuracy is poor.
In addition, standard capacitors are generally more accurate than standard inductors, so standard capacitors are usually used for
comparison.
- Fire detector made with photodiode
- Temperature-frequency conversion circuit composed of CD4046
- 4-range digital voltmeter circuit using ADD3701
- Transistor reverse breakdown voltage tester-----Transistor tester
- A low-cost inductance meter consisting of a single IC
- AC ammeter circuit
- Fluorescent tube inverter circuit and emergency lighting circuit 02
- Simple password electric lock
- 3W portable megaphone circuit
- Multimeter DC voltage measurement circuit
- Motor forward and reverse control wiring diagram (2)
- Set timing circuit when power is on
- Inpatient pager circuit
- Peanut and melon seeds roasting machine circuit
- Farmland drainage automatic control circuit
- base amplitude modulation circuit
- Voltage series negative feedback amplifier circuit
- color discrimination circuit
- High and low frequency signal generator circuit
- Guest arrival signal recognition circuit
