Operational Amplifier Concept
Source: InternetPublisher:三岁就很酷 Keywords: Amplifier Updated: 2024/09/10
An operational amplifier is an amplifier with two input terminals and one output terminal. It amplifies the voltage between the two input terminals at a very high rate and then transmits it to the output terminal.
Operational Amplifier Logic Coincidence Diagram
If the operational amplifier is represented by a circuit symbol, it can be represented as a triangle as shown in the figure on the right. Its two input parts are called non-inverting input (1N+) and inverting input (IN-). It amplifies the voltage between the inverting input terminal and the non-inverting input terminal with a great amplification rate, and then outputs it from the output terminal (OUT).
A package that contains one operational amplifier circuit is called a single operational amplifier, a package that contains two operational amplifier circuits is called a dual operational amplifier, and a package that contains four operational amplifier circuits is called a quad operational amplifier. The circuit using a quad operational amplifier can be smaller in area than a circuit board assembled using a single or dual operational amplifier. In almost all packages, if it is a single operational amplifier, a tube shell package or an 8-pin dual-in-line package is used; if it is a dual operational amplifier, an 8-pin dual-in-line package is used; if it is a quad operational amplifier, a 14-pin dual-in-line package is used. In addition, in general, the arrangement of the pins is generally universal, although there are exceptions. For operational amplifiers used by amateurs, only the above-mentioned packaging methods may be used. Therefore, it will be very convenient to understand the distribution of this lead.
- Voltage divider circuit calculation formula, where to find the voltage divider circuit?
- How are diodes made using semiconductors?
- What are the classifications of filters?
- How to calculate the value of capacitors in parallel?
- Simple Wired Spy Bug Circuit Built Based on IC741
- How to build a drag racing timer circuit using a 7-segment display and discrete components
- Analysis of three simple electronic dice circuits
- Ceramic filter structure/working principle/characteristics/application
- Touch circuit design and analysis
- LED Night Light
- Ultrasonic proximity sensor circuit
- High input impedance three op amp differential amplifier circuit diagram
- Differential bridge amplifier circuit diagram
- Low drift peak detector
- Op amp impedance multiplication circuit
- Variable gain operational amplifier circuit diagram
- A crystal controlled local oscillator circuit diagram
- variable gain amplifier
- Inventory of radio frequency interference rectification error circuits in amplifiers
