Electric system voltmeter circuit
Source: InternetPublisher:张三叔 Keywords: Voltmeter BSP Updated: 2020/08/29
The voltmeter is composed of a fixed coil and a moving coil in the measuring mechanism connected in series and equipped with a certain additional resistance. Nl is fixed coil,
N2 is moving coil, R. , Rz is the additional resistance, U1 and U2 are the voltage limits.
When the additional resistance R is greater than the inductive reactance of the fixed coil and the moving coil,
the effective value of the current in the fixed coil and the moving coil is
I=U/R
in the formula U-the effective value of the measured voltage;
Ni-the additional resistance of the voltmeter .
The deflection angle of the voltmeter is calculated by the formula a=KU/Rz.
It can be seen that the deflection angle of the pointer is proportional to the square of the effective value of the measured voltage,
so the scale graduation is also uneven. Similarly, the electromechanical voltmeter can measure DC voltage and the effective value of sinusoidal AC voltage and non-sinusoidal AC voltage
- Multimeter with small capacitor test circuit
- Detection of Bidirectional Trigger Diode
- Simple and practical motor short circuit tester
- Simple electric tachometer
- Analysis of valid and fault conditions of differential signals
- Fire detector made with photodiode
- How to Simplify Analog Front-End Design for Heart Rate Monitors
- AC ammeter circuit
- High Performance Digitally Controlled Amplifier-Gain Divider
- A simple no-load self-stop circuit for welding machines
- Motor forward and reverse control wiring diagram (2)
- Self-defense anti-riot circuit
- Egg warming circuit
- Integrated synchronous detector composed of analog multiplier MC1596
- Diode square rate detection circuit
- Amplitude modulation circuit composed of MC1496
- Diode balanced amplitude modulation circuit
- Voltage series negative feedback amplifier circuit
- color discrimination circuit
- Sine wave signal generator circuit
