Zero-crossing trigger circuit diagram based on thyristor
Source: InternetPublisher:黄土马家 Keywords: SCR circuit diagram trigger circuit AC voltage Updated: 2021/01/29
The zero-crossing synchronization pulse is a pulse at the zero-crossing moment of the 50Hz AC voltage , which enables the thyristor to trigger conduction when the AC voltage sine wave crosses zero. The zero-crossing synchronization pulse is generated by the zero- crossing trigger circuit . A more detailed circuit diagram is shown in the figure. In this figure, the voltage comparator LM311 is used to convert the 50Hz sinusoidal AC voltage into a square wave. The positive edge and negative edge of the square wave are used as the input trigger signals of the two monostable triggers respectively. After the two narrow pulses output by the monostable trigger are mixed by the diode or gate, the process corresponding to the AC 220V mains power can be obtained. Zero sync pulse. On the one hand, this pulse is added to the temperature control circuit as a trigger synchronization pulse for the thyristor , and on the other hand, it is also added to the T0 and T1 terminals of the 8031 as a counting pulse.
- The basic principles of power supply design. What are the key components of a power supply?
- Basic characteristics of power field effect tubes, how to improve the dynamic performance of power MOSFET
- Schematic diagram of car cigarette lighter to USB power port
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Driving circuit of switching power supply field effect tube
- ISO113 circuit that can reduce power consumption
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- LNK304 non-isolated LED light string driver circuit
- A novel and practical DC low voltage stabilized power supply
- LM317T voltage regulation adjustable circuit diagram explanation
- Zero-crossing trigger circuit design based on thyristor
- Zero-crossing trigger circuit diagram based on thyristor
- Triac two-tone dimmer (2)
- Triac two-tone dimmer (1)
- AC voltage over and under voltage protection circuit
- Thyristor circuit with sensitive trigger gate inductive load
- A simple method to check the thyristor tube
- Triac light dimmer
- Triac trigger circuit for flashlights
- Internal schematic diagram of contactless AC relay
