Protection measures for operational amplifier differential mode voltage breakdown input stage
Source: InternetPublisher:王达业 Keywords: Overvoltage protection circuit Updated: 2024/09/09
The overvoltage protection circuit without internal protection measures is shown in Figures (a) and (b). Figure (a) is a diode protection circuit, and Figure (b) is a voltage regulator protection circuit. In specific applications, it is sufficient to select one of them. The resistor in the figure is a current limiting clamp resistor. Its value is as high as 10kΩ and will not reduce the offset voltage. In practical applications, the input end of the resistor may be the signal input end. Usually, in order to improve DC accuracy, it is hoped that each input port branch is connected to an equal resistor. In some cases, as long as the input resistor and the feedback resistor can limit the current of the clamp diode, one or two resistors can be omitted.
- DS1669 Digital Potentiometer
- Application of digital-to-analog converter DAC0832 (including circuit and source code)
- The Basics of Op Amp Loop Stability Analysis: A Tale of Dual Loop Gains
- Transistor working state: detailed explanation of transistor cutoff region, amplification region and saturation region
- Common source amplifier circuit diagram
- Principle of multiplier voltage rectifier circuit
- Four constant current source circuits and their applications in integrated operational amplifier circuits
- How to Remove Power When Using a Fully Differential Amplifier
- How to Build a TIA Circuit Using a Fully Differential Amplifier
- Calculating the Input Impedance of a Differential Amplifier
- Overvoltage protection circuit
- Zener diode overvoltage protection circuit 02
- Zener diode overvoltage protection circuit 01
- Color TV main power supply overvoltage protection circuit
- Overvoltage protection circuit diagram
- Stabilized power supply with overvoltage protection circuit diagram
- Overvoltage protection circuit diagram using TL431 precision reference source, etc.
- Overvoltage protection circuit diagram using CW136
- Thyristor AC overvoltage protection circuit
京公网安备 11010802033920号
